Label based entry and exit from activity
Dear All,
I am trying to build logic for work item exit based on label matching. Consider this example.
I have Start point, Queue 1, Activity 1, Activity 2 and End Point.
Work item A1,A2,A3,A4,A5 labeled attached as 1,2,3,4,5 are entering in Queue 1 and Activity 1, till here it is fine.
Now I want after Activity 1, using label sequence as 3,4,1,2,5 work items should enter in Activity 2 e.g. first A3 than A4 than A1, A2 and A5 respectively. So after Activity A2, work items should exit in A3, A4, A1, A2,A5 sequence.
Thank you.
Best Wishes,
Kumar
Thank you.
Best Wishes,
Kumar
Hey Kumar,
it looks like your answer is in another post here:
https://community.simul8.com/index.php?p=/discussion/7680/need-help-to-build-visual-logic-based-on-label-value#latest
Good luck.
Ali
