Set Multiple Variables to Values from Spreadsheet Using a For Loop
I am pulling in values for variables from Excel and placing them into a spreadsheet within my Simul8 model. When I am trying to set variables within the system (i.e. times and probability distributions) I have not found a way to set these values all at once within a loop. Instead I am writing one line for each variable that needs to be set in the form of, where 5 is the fifth column in my Var1 spreadsheet :
Set Prob-Profile Distrib Column dist_ProductType , 1 , 1 , Var1[5,1]
Set Prob-Profile Distrib Column dist_ProductType , 2 , 2 , Var1[5,2]
Is there a way to write a loop so that does not have to be repeated tons of times in the form of:
for i=1:n
Set Prob-Profile Distrib Column dist_ProductType , i , i , Var1[5,i]
end
As I add more and more complexities to my models having to write multiple lines of codes to simply set a variables gets excessive.
Any help would be appreciated.
Hi there, you can use the LOOP command in Visual Logic, where you'll be able to set the number of iterations, i.e.
Loop 1 >>> i >>> [Number of iterations]
Here's the help for this: https://www.simul8.com/support/help/doku.php?id=features:visual_logic:commands:loop
Maksim
