Issues with Running Trials — SIMUL8 Community Forum
N_SowardsN_Sowards
When I run trials of my simulation I am getting only 1 run that has actual data and all of the other runs have 0 for all the other values. Any insight as to why this might be happening or has this happened with anyone else?
    Hey, I discovered recently that when after running trials, if you click the copy button on the top right corner of the Results Manager (under the KPIs tab), and you paste results, you paste results of all Runs. If you are running trials with the Scenario Manager and you want to see all runs, you need to go to File>Preferences>Results and check "All Runs" under Trials, this will give you all runs of each value. - Jakob
